Range Rover HSE 4.6 not firering......
Old Jul 23, 2008 | 07:29 AM
snuif's Avatar
3rd Gear
Default Range Rover HSE 4.6 not firering......
I have a 97 Range Rover 4.6 and it turns over but will not fire. I get no spark from any spark plug wire. What are the components to check?
It always runs fine, after a broken cooler and wet wirings it no longer runs, he is dead.......................??????
Following message in display: "Left window open, Roof Open, Right open, Engine Blocked" also many messages.
HELP, HELP............[&:]
Thanks for any help, i'm from the Netherlands
Old Jul 23, 2008 | 03:08 PM
Rotorhead1959's Avatar
Default RE: Range Rover HSE 4.6 not firering......
First check all of your fuses. If those are all good ,check your crank sensor. This is often the reason for this type of condition. The messages you are getting is because at some point you disconnected the battery. Bring each window up and down (complete cycle) and your messsages should go away.
Old Jul 24, 2008 | 03:54 AM
snuif's Avatar
3rd Gear
Oke, first THANKS for the quick answer.
I will try, at first i have to let him regonice the key, because thats a new massage.
I let you know how its gone.
On the passenger drivers side (Eurpean Version) i found a totaly oxcidated connector (green oxcidated water) wich goes to the
Body Electrical Control Mod-ule (BECM), so that thing is to repair first.
AmexBlackG5
Jun 25, 2008 01:04 PM
umoms
Apr 3, 2008 06:22 PM
JimMayor007
Dec 5, 2007 08:46 AM
Stickestar
Appearance & Camping Set Ups
Dec 13, 2006 03:25 AM
