Rear ELectronic Differnential
Old Oct 31, 2009 | 12:41 AM
kailash6789's Avatar
3rd Gear
Default Rear ELectronic Differnential
Hi All,
on 2010 Range ROver, there is an Option called "Rear ELectronic Differnential".
Whats does this feature do? SHould I buy that option for better off-road performance?
Thanks
Old Oct 31, 2009 | 09:13 AM
Jordanmd88's Avatar
Should be an electromagnetic Locker, ask your sale rep he should be able to correctly answer this..
Old Oct 31, 2009 | 12:09 PM
LRScott's Avatar
I would recommend it, especially if you will take it off road. It will also help dramatically in snowy and icy conditions.
Old Nov 1, 2009 | 07:30 AM
3rd Gear
OK, Thanks
Old Nov 1, 2009 | 07:31 AM
3rd Gear
Scott,
thanks a lot. Will get it
Old Feb 14, 2010 | 11:54 AM
moormerland's Avatar
5th Gear
Sales Rep? Come on, these guys don't know what a spark plug is.
The electronic differential has the same functionality and gear ratio as an open differential, but also incorporates a locking and torque biasing function to give improved traction performance and vehicle dynamic stability. The multi-plate clutch actively controls the torque flow through the differential and optimizes the torque distribution in the driveline. The clutch biases the torque from the differential to the wheel with the higher grip and prevents the wheel with the lower grip from spinning.
kwilkins
Jun 5, 2011 10:43 PM
cowboydan
Jan 16, 2007 11:53 PM
katana1
Jan 12, 2007 11:16 PM
katana1
Jan 12, 2007 11:01 PM
h.fork
Sep 26, 2006 04:07 AM
