recovery from tank of water into gastank....
the rover seemed to run out of gas and the nameless persons trying to resolve the situation put old gas with a gallon of rainwater into the tank. Seems I've got that situation worked out by fuel pump draining it "dry", changing fuel filter, tore off plenum, removed injectors to clean out the junk/water/bad gas, bleed out fuel rail.
before the draining it would start and run on quickstart and a gas spray bottle -- I know it's dangerous -- singed my arm hair good with it. no more of that...
So, with 5 gallons of fresh gas in there, 2 cans of heet (iso.alcohol), and battery charger -- crank and crank -- now not even a pop (with or without quick start). Seems like no spark.
put a "noid" or Node light on the electrical connector for an injector and no glow -- seems no current going to the injector.
the only electrical thing I know that works is the 3 sec fuel pump at key on.
So -- was it really out of gas or did a relay or ECU go out? Any other ideas ??
aguison
11-18-2012 05:15 PM
Team140
08-30-2009 09:41 AM
