removing land rover badge
Old Dec 6, 2005 | 02:20 PM
tonyking's Avatar
Default removing land rover badge
hi - does anyone know the best technique in removing the land rover badge from the tailgate?
Old Dec 6, 2005 | 07:12 PM
Randy Lover's Avatar
Default RE: removing land rover badge
i would just use a phillips screwdriver, the flat ended ones you know, dunno what they call them in the US (if your from the US)
might damage the paintwork tho if your not carefull
Old Dec 6, 2005 | 09:20 PM
teamyonex's Avatar
I heated it up real good with a hair dryer, then used fishing line to pull behind it. Whatever adhesive is left behind is easily removed with a rag lightly dipped is gasoline. Soap and water afterward. It's a simple job. If you are talking about the HSE letters on the MkIII, those come off even easier. I didn't find the need to use anything as mechanically harsh as a screw driver.
Old Dec 17, 2005 | 01:54 AM
Rob V.'s Avatar
heat up with dryer and use dental floss to remove badge, dont even think about using a screwdriver.
Old Dec 17, 2005 | 08:02 AM
oh well i obviously was wrong but hey, ive never done it before
Old Dec 18, 2005 | 02:12 AM
JTravis's Avatar
Well, right then, there you are! *puts the Sawzall back in the toolchest*
Old Dec 18, 2005 | 02:59 AM
05LandRover's Avatar
only i call them straight not slot
::EDIT:: my 700th post!
Old Dec 18, 2005 | 07:26 AM
woooooooo, go you. quite an achievement
ArmyRover
Off Topic
27
Jun 29, 2015 04:11 PM
branard66
May 24, 2014 07:18 AM
branard66
May 23, 2014 12:02 PM
beaubrant
Jun 14, 2012 01:15 AM
honda50r
Feb 29, 2012 11:06 PM
