rrc classic 95 lwb...high idle
Old Aug 29, 2016 | 02:13 PM
newworld's Avatar
Default rrc classic 95 lwb...high idle
1995 rrc lwb.
have a high idle on startup 1300-1500 rpm then 1200 rpm after several minutes....while driving around around 1000 rpm. if after driving you stop and put in park...idle will rise 1500+ starts spiking
i tried adjusting idle screw but same thing....changed stepper....same thing...its an annoying problem .......i am a bit worried about shifting from park to reverse and drive when idle is high...clunk etc
Old Sep 13, 2016 | 09:26 AM
pl626's Avatar
6th Gear
I'd check the stepper again, but you may also want to check the TPS. Plug a Rovergauge to see what's going on with the 14CUX. I had a bad TPS that was telling the 14CUX it was redlining when it was actually idling. Check your vacuum lines for cracking as well.
wick_60010
Nov 22, 2017 04:25 AM
WNYErikDiscoII
Nov 7, 2013 09:32 AM
Lincoln Tarantino
May 2, 2012 11:20 AM
Cosmic88
Feb 16, 2011 03:08 PM
blast20
Nov 29, 2010 08:44 PM
