RRC Code 44
Old May 24, 2012 | 07:59 AM
drowssap's Avatar
Default RRC Code 44
i have 1990 RRC and had the cel come on, when i checked the "black box" it had a code 44.
which i believe is the driver o2 sensor?
any tricks to replacing the lh o2?
any universal o2's that fit that anyone knows of or should i only use oem like a Disco?
Old May 31, 2012 | 09:30 AM
drowssap's Avatar
really; no one has replace a 02 sensors on a RRC
Old May 31, 2012 | 09:42 AM
hilltoppersx's Avatar
check the wiring to the sensor before actually buying a sensor. make sure its just not a short in the wire. if the sensor is dead then you need part ERR6729 around $100 each side. need 2.
Old Jun 1, 2012 | 06:05 AM
drowssap's Avatar
thank-you
WNYErikDiscoII
Nov 7, 2013 09:32 AM
doxster22
Oct 23, 2012 04:44 PM
Lincoln Tarantino
May 2, 2012 11:20 AM
Paul Grant
36
Mar 14, 2012 07:59 PM
sayeedA
Nov 15, 2011 11:02 PM
