RRS HEADLIGHT OUT!!
Old Feb 13, 2008 | 06:42 AM
strandidNOLA's Avatar
Default RRS HEADLIGHT OUT!!
Today on my way to work I noticed that one of my headlights were out. Is this covered under the warrranty and if not how much is something like this cost to have fixed? is it something I can fix myself???
THANKS
STRANDID
Old Feb 13, 2008 | 11:20 AM
Default RE: RRS HEADLIGHT OUT!!
What year and how many miles????????????????????????????????????????????? ????????????
Old Feb 13, 2008 | 10:10 PM
Pads Fan's Avatar
If it's just a bulb, you should be able to just swap out the old bulb for a new one. Do you know how to do this? I'm not sure the set-up of the headlamps of the Range Rover Sports but if it's like the older design Range Rovers or most cars on the roads, you should be able to stick you hand behind the lamp housing and unscrew the cover that's attached to the backside of the lamp housing. Once the cover is off, unplug the old bulb (usually twist or turn the bulb clockwise or counterclockwise and unplug the wire) and plug in and secure the new one inside the housing. The bulbs are plug and play. You could surely buy a set of bulbs for your model online somewhere. Your bulbs may be under warranty, though, since your truck is a 2006 or newer, I'm assuming and if that's the case, have the dealer take care of it. Do you live near an ocean? When I had my RR, I lived near the beach and almost every lamp on my truck prematurely crapped outdue to salt in the air corroding the bulbs. Many cars in my beach community had headlight and brake lights that burned out out from the salty air. Nothing you can do about that.
Pads Fan
Old Feb 14, 2008 | 08:27 AM
raid13's Avatar
yes is covered under factory warranty
most likely not bulb, i have been seeing a lot of ignighter modules
going bad. zenon bulbs have no filiment to (burn out).
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
Disco03
Dec 1, 2008 08:08 PM
incubus
Aug 30, 2007 09:23 AM
disco12
Off Topic
Mar 14, 2006 09:30 AM
