Select Neutral
Old Jan 25, 2006 | 06:20 PM
samsly's Avatar
Default Select Neutral
I started getting this message in the car yesterday morning, does anyone know what that means before I head to the stealership..??? [>:]
Old Jan 25, 2006 | 07:53 PM
05LandRover's Avatar
Default RE: Select Neutral
is it trying to go into low range?
Old Jan 26, 2006 | 01:35 PM
samsly's Avatar
I'm not sure what its doing!!
Old Jan 26, 2006 | 09:57 PM
esaycho's Avatar
Well if you put it from High Range to Low Range and didn't keep it in neutral or from Low to High and again did not put it in neutral, you need to keep it in neutral until it says High or Low. If you didn't do that then i would just say put it in Neutral and then wait for something to happen
Old Jan 27, 2006 | 01:19 AM
samsly's Avatar
Left it on Neutral for at least 10 mins, when I switched it to drive or park, the note states the same thing... I did have a guy come here to Detail the car for me, maybe thats when it happened.. [:@]
Old Jan 27, 2006 | 10:39 PM
esaycho's Avatar
Did he touch the interior at all, and if so is it possible that some kind of cleaner messed up something in the gear/HI LO connections?
Old Jan 29, 2006 | 10:05 AM
samsly's Avatar
Yes he was in there spraying and cleaning. maybe it did mess something up... I pray it is not a MAJOR problem.. Not sure if it is a mental thing, but the car has not been driving the same since then!
Old Jan 29, 2006 | 01:34 PM
esaycho's Avatar
I would think that he got some kind of wires wet that effects something, he could have done this to the window controls as well, check to see that windows work and the Power mirrors work when you press the button on the controller
Old Jan 29, 2006 | 11:28 PM
Bait's Avatar
ORIGINAL: samsly
Sure do ! It indicates a problem with your transfer box. TIB on the issue.
Old Nov 20, 2007 | 10:45 PM
olivia's Avatar
Did you ever find out why Select Neutral came up?? Was it the Tranfer case or the Transfer Case computer under the passenger seat??
Appreciate the help
Mike
