Sirius radio
RE: Sirius radio
Yes it is completly possible.
check out www.bimmernav.com under the section for Sirius.
Basically here is what you need to do
Upgrade the Radio module in the trunk: Gives you support for Aux input, Sirius, and BMW Cd chagers the play MP3 and show ID3 Audiotext
upgrade the navigation computer to BMW DVD Nav: Displays the sirius channels on the nav screen, ID3 text on nav screen (with new changer) and also supports 3D map viewing.
All of these are completly possible and easy to do.
I can help with the install for a $45 an hour if you are near Austin Tx. or completly guide you over the phone for the same amount
Martin
Martin
RE: Sirius radio
OK now this is what I like to hear. What I need is an actual list of parts to purchase or can you provide them? I may try to do this myself with you on the phone or I may have you walk an installer through. I really appreciate this. Thank you Thank you woooooohooooo Merry Christmas to me woooooohooooo
RE: Sirius radio
I do not sell the Stuff for Sirius, but here is what I would suggest you start with
http://www.bimmernav.com/BMW_Sirius_..._Retrofit.html
BMW Trunk Mount Radio - P/N 65 12 6 976 961 OR NEWER $430-with Sirius and BMW MP3 Audiotext support
BMW MKIV Navigation Computer try ebay
P/N 84 11 0 150 526 CD Changer Extension Cable $12.08 OR P/N 84 11 0 141 978 2.1m CDC Extension Cable $13.80 depending on your application
P/N 84 11 0 153 365 Sirius Receiver $229.95 UPDATE!!! As of the original info BMW has a new part number 65.12-0 398 140 which works with both nav and non-nav cars.
P/N 84 11 0 390 239 Low Profile Antenna $50.00 OR the TREK solution SIR3 and SIR-SP
email parts@crevierbmw.com for the parts Say you are a "roadfy member" for 20% off (No way for them to check)
Connect either the Sirius stuff directly to the CD changer in the front, or what i would do is get everything connected in the back. You can also replace your CD changer with the BMW changer that plays MP3s http://www.bimmernav.com/bmw_mp3_cd_changer.html
The Bluetooth stuff is on this page
http://www.bimmernav.com/Rover_Bluet...tructions.html
If you are in the Austin, Tx area I can install any of this stuff for $45 an hour 1-800-891-1335
Martin
Martin
RE: Sirius radio
Here is a better write up for the Sirius
Full details and step by step instructions
Rover Sirius Upgrade
