srs light
Old Jan 22, 2008 | 11:14 PM
hanivw's Avatar
Default srs light
hello i have a p38 96 rover my srs light is onn all the time like it flashes some time and stay onn constant , can u help me out , where to look for the problem and how to fix it ............please thanks
Old Jan 22, 2008 | 11:18 PM
WolfPack's Avatar
Default RE: srs light
EDIT: After your last post, I think it's a battery issue. Get it checked like I said in your other post. The SRS system operates on voltage signals, and any change in the system's power can throw it off. Get it checked and post up your results.
What year is your Rover? Also get your codes pulled, I can't recall if the SRS system will throw a code specifically or not, but it's the best place to start. Act fast though, that is a rather important system to the safety of you and your vehicle's occupants.
Old Jan 24, 2008 | 09:53 PM
hanivw's Avatar
thanks for the response guys, well i went and got a new battery , the srs light still on and says air bag default and the sport switch tranny still doing the same also plus and the engine check light still onn...........its a 1996 ranger rover s.e the code show p-1703 manufacuter malfunction trannsmission , i need all the help please guys thanks, its drving me crazy thanks for helping
Old Jan 24, 2008 | 09:58 PM
WolfPack's Avatar
well..since its a 96, air bags should be serviced after 10 years, so you're due for a check on those anyway. I'd say take it by your dealer and say you need the air bags checked, and they should get to the bottom of the SRS warning.
Since the P1703 code is a manufacturer code, we'll need Disco Mike or someone more expert than I to fill us in on what specifically that code means.
Old Jan 25, 2008 | 12:50 PM
The only way to find out for surewhats wrong/ repair and reset the SRS light is with a lap top scanner like an Auto Logic scanner or the dealers test book.
Low voltage is a possibility but if it is going on and off, I would rull that out and look at the seat belt sensors, this of course won't help you because it takes the scanner so go find a shop.
robdis96
May 21, 2007 08:05 PM
RJADM2000
Dec 11, 2006 06:59 PM
bphiggins
Aug 21, 2006 12:31 PM
Rovercountry
Dec 25, 2005 09:42 AM
anonimaus
Mar 14, 2005 12:39 AM
