steering issue on 91 classic
Ok so I've been doing some research and came across this - which begetsthe question at the end:
If your steering feels even a little loose, your Range Rover steering boxes may need to be periodically bled. This is the first thing to check. Tiny bubbles have a tendency to collect in the steering box. New fluid and a thorough fluid-letting of the system has been known to do wonders in many cases. The power steering unit uses a standard Dexron IID fluid. [align=left]Atlantic British has found that installation of a new standard or premium gas steering stabilizer* has done a great job in removing the "shudder" in the steering. If you are having problems with steering shudder, bleed the system. If the problem persists, look to the steering stabilizer - before getting involved with a full front-end rebuild. A new stabilizer may be all you need. Atlantic British offers a *premium Bilstein Steering Damper (# 6497B) and also a standard Woodhead Steering Damper (# 6497) [/align][align=left][/align][align=left]How does one bleed the steering box ? And what do they mean by a thorough fluid-letting? How do you do that?[/align]
Vinndego
01-06-2014 11:14 AM
range95
07-08-2011 08:29 AM
tre976
04-16-2008 08:33 PM
MONTANACW
01-23-2007 01:00 PM
