still no brakes
Old Jun 22, 2010 | 11:21 PM
sickvehicle's Avatar
Default still no brakes
abs pump is working? what next is the abs pump sapose to cut off i dont think mines does it stays running when the trucks on or the key on?
Old Jun 23, 2010 | 01:24 AM
LRScott's Avatar
The brake pump should eventually shut off after building pressure. The pump's relief valve could be stuck open, or it could be a leak in the modulator.
Old Jun 23, 2010 | 08:27 AM
Default brakes
i brought the truck like this so i dont know what caused the failure i will check for leaks asap and get back to u i had to post this again because no one ever replied backed to my first post after i came back with more info..so thanks for the info...i really need help..
Old Jun 23, 2010 | 08:29 AM
Default valve
where is relief valve locate?
Old Jun 23, 2010 | 05:41 PM
LRScott's Avatar
Inside the pump. http://www.yourwebdesigns.com/abpmp/
Old Jun 23, 2010 | 07:24 PM
wilson96rr's Avatar
How long did you wait for it to cut off?
Old Jun 24, 2010 | 08:20 AM
Default brakes
about 2 mins i im thinking modulator? what about these so called repair kits that replace the plastic washers anybody ever try this
Old Jun 24, 2010 | 11:07 AM
First, what year is it, makes a difference?
How well do the brakes work when you stop hard, how about if you stop hard 3 or 4 time do they loose stopping power, if so it could be the accumulator not holding pressure, either way get some one to look at it before you burn up the pump.
Old Jun 25, 2010 | 08:44 AM
95 p38 and the accumulator is new and when i step on brake there is no brakes at all im not driving the truck so burning up the pump wont happen i just pulled out the modulator and was just wondering should i be able to push the shaft in with out power applied to it? also when i got the truck it was like this
peadl would just go to the floor...
Old Jun 25, 2010 | 12:40 PM
LRScott's Avatar
You've got an internal leak somewhere. I'd put my money on that plastic washer having disintegrated. If it were me, I would just purchase a used modulator from a parts rover. Before you replace the modulator, make SURE the pump is pumping fluid. Disconnect the out going high pressure line, turn the ignition on, and see if it pumps fluid.
