Sunroof Not Set??
Sunroof Not Set??
Help,
I have a 1998 4.6 HSE. Recently the sunroofsunshade was shut and jammed into the headliner. When I went to open the sunroof, not knowing this, the display read "Sunroof Not Set." The sunroof only opened a couple of inches and stoppedbut then I was able to free the sunshade and now it works fine but the message still appears. Does anyone know how to set the sunroof and get the message to stop appearing?
Thanks,
Jeff
Thanks,
Jeff
RE: Sunroof Not Set??
It's in your manual!
But, in case you don't have one, the step is the same for the sunroof, and all windows. With the sunroof closed, just hold down open, once it's done opening, immediately rock the switch back to close position, and hold till closed.
Same as flyplanes said, but...no need to hold it down for extra time..that usually causes my attempt to fail
bagocheetohs
08-11-2015 06:13 PM
davidlafrance
03-09-2011 05:30 PM
nick731
11-16-2010 12:25 PM
diego rover
11-07-2007 04:22 PM
bavarian_range89
10-31-2007 01:51 PM
