Supporting Mods for OME HD coil conversion
![Red face](https://landroverforums.com/forum/images/icons/icon11.gif)
Hey, Forum
So I pulled the trigger and bought the front and rear HD coil springs for my P38.
Now. I want to know what else she'll NEED. I was going to put in new u-joints(stock) but with the new coil I figured I'd get HD ones as well from RandC4x4 GKN brand.
What else might she need? She's got brand new bilsteins on all 4 corners.
I want to do wheel hub bearings on all 4 corners so I'll probably do that.
What bushings should I get at while in there? Is there a bushing upgrade kit?
I also am torn between the OME and Terrafirma steering dampener. Gonna do some research on those right now.
Thanks!
Best,
Ashtray
edit: Ah! And I got an EAS harness clip from AB. Forgot to mention that.
Thanks!
Best,
Ashtray
On the damper I would get it to match, but I e the tf nothing wrong with it.
You can get great deals on hubs on eBay, like $75 each with new sensor s.Taylor is the manufacture.
Hey, Forum
Thanks!
Best,
Ashtray
Thanks!
Best,
Ashtray
As far as perches or things like that...the springs are drop in correct?
Just an update!
Ending up getting the TerraFirma HD coil conversion kit. Super cheap, came with brand name coils, override harness and all other components needed for the install + instructions. Should be going in soon.
she already came in and I just need to plan a space of time to install. I also got my HD ujoints but the seller messed up and only sent 1 set as appose to 2 sets which is what I ordered. I'm getting the second set in another horrible 2 weeks.
On a side note I also purchased a battery cover for under the bonnet since my Rover did not come with one.
