SUSPENSION
Old Dec 24, 2008 | 12:36 PM
roverfun's Avatar
8th Gear
Default SUSPENSION
i have a 2000 p38. Currently all the lights for the suspension settings are on and the air bags are at the highest point and will not go down. I checked all teh fuses and are fine. Im leaving on vacation friday of course. Any help is greatly appreciated....
Old Dec 24, 2008 | 03:33 PM
ldivine's Avatar
Default RE: SUSPENSION
Soft faults can be problematic.
If it's defaulting to max hight the EAS ECU may think the vehicle has become stuck. If this is the case it will go to the max setting to clear the "obstacle".
Check for loose wires on sensors. Also i'd check the 35 pin connector under the seat. There is some stuff on the net http://www.falconworks.net/EAS/ that there was an assembly problem with the connectors during their manufacture (the jigs were not straight or some such thing) and that the pins can get out of alignment...
Personally, I wouldn't drive it in it's current condition so as to prevent any further problems. And because it's not all the safe to drive in the extended height profile (especially on the highway).
Old Dec 24, 2008 | 05:37 PM
roverfun's Avatar
8th Gear
i appreciate the help so much, Where are these sensors i should be looking for? and what do the look like
Old Dec 24, 2008 | 08:17 PM
ldivine's Avatar
The sensors are mounted under teh chasis. One for each wheel. The potentiometers are linked to the front radius arms and rear trailing links. Pretty sure there's a diagram in RAVE.
I posted a link to RAVE in a recent post. Within RAVE it should be in the suspension section. Let me know if this helps.
Regards
Old Dec 24, 2008 | 11:18 PM
ldivine's Avatar
And you can google search for range rover height sensors and go to the pictures section. Some decent ones pop right up!
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
Aaron Sandland
Feb 12, 2015 09:35 AM
fastrx7man
Jan 28, 2012 12:49 PM
