temperamental auto
Old Apr 24, 2006 | 06:14 PM
chris^t's Avatar
Default temperamental auto
I have a very temperamental and annoying fault with my 1990 efi auto gearbox.When first started from cold,the gearbox will not change up even when iv changed the oil and filter in the box.To get the gearbox to change up i have to rev it in first gear up to about 3500 revs then it works as normal for the rest of the day until left overnight. the problem is no better even after changing the oil and filter in the gearbox.Any suggestions will be greatfully appreciated.
Old Apr 27, 2006 | 09:46 PM
Default RE: temperamental auto
Sounds like you have a valve sticking in the valve body. Depending on your mileage, there may not anything you can do. If you wanted to try something, you might consider running a bottle of Lucas transmission additive thru your tranny, I know many people have had good results with it.
Mike
razorbak
Oct 5, 2020 02:41 PM
PabloM
Sep 17, 2012 02:45 PM
Garry
Oct 30, 2005 02:06 PM
Bene
Oct 27, 2005 03:30 PM
Hobes
Jun 28, 2005 02:46 PM
