Tire Pressure?
Old Jun 8, 2010 | 12:56 PM
cpn LR's Avatar
Default Tire Pressure?
What tire pressures are you running? The placard on the door says 28 front and 38 rear. That sounds pretty low for the fronts.
BTW this is for an 02 HSE
Old Jun 8, 2010 | 01:08 PM
krazzz's Avatar
I agree, it seems low to me too. I tested it at that pressure and also at 36 psi and didn't find any difference. Since I do a lot of highway driving I keep front and rear at 36psi. The most important thing is to stay within the specs of the tires.The max PSI can be found on the sidewall.
Old Jun 8, 2010 | 08:00 PM
cpn LR's Avatar
Thanks. I realized I hadn't adjusted the tire pressure after I rotated the tires and it seemed to ride and handle fine. I will bump it back up to 36 lbs or so.
Old Jun 8, 2010 | 08:08 PM
aemnky606's Avatar
I run all mine at 40 psi.
Old Jun 8, 2010 | 08:46 PM
wilson96rr's Avatar
I run mine at the pressure indicated on the door. I figure that a lot of testing went into coming up with those pressures.
oncorhynchus
Jan 21, 2007 02:14 PM
lpx
Jan 15, 2007 06:57 AM
agavrilo
Nov 16, 2006 12:19 AM
T3LU_03
Jun 8, 2006 03:18 PM
kensei
Jan 1, 2005 09:01 AM
