Trans Fail-Safe Prog
RE: Trans Fail-Safe Prog
My 03 Range Rover began pullin hills strange once I would get to a hill it would not shift out of second gear until I reached flat land and let go of the gas pedal, next it jerked a couple times when i put it in gear, then one day while driving it jerked after accelerating from a stop light and flashed trans. failsafe prog. it would only drive in 1st and 2nd gear then I pulled over and put it in park turned the car off and restarted it and then shifted into drive and it just drifted backwards, that same day I went up to the dealership after having it towed up there and started it up and put in drive and rev. and it worked fine. Dealrship said they found some high resistance wires and bad connections but also say they believe that there is internal transmission problems and they start at $10000. It has 62000 miles on it very clean. Any suggestions on what too look for so I dont get over-chargedd by dealer?
My 05 Rover is showing the "trans failsafe prog" in the message center ONLY when I am driving...it has done a few times. It seems if I put the key in the first position to reset...it won't show it. Never had any probelms with the transmission. Never had any real problems with my Rover at all. However, I did just replace the battery with a M-93 Interstate battery...it was recommended by Interestate Battery for the rover....I have noticed that many folks first question on different forums is in regards to the battery/lowvoltage....could this be the issue? Don't feel like spending 4k for a new transmission...any suggestions?
needs it diagnosed. Trans fail message won't give you the code so you need to know what is the problem.
I have seen some issues with clip on the inner boot causing issues or even a stuffed radiator. But need diagnosis.
oh and I have seen the converter bite the dust destroying the trans a few times as well.
I do not see how the weight of the engine oil has anything to do with the transmission so it should not be an issue.
I would take it in and have the tranny looked at, it could be something simple or it could be bad and will just get worse and more expensive as you try to keep driving it.
I had a BMW that would do that now and then, found it was in the gear selector that would trick the message display into thinking there was something wrong, the tranny was fine.
Trans Failsafe
Hi, I also have the trans failsafe message coming up, my car does not seem to go into gear and just revs up although if I turn the car off, lock it and then start it up again it will go into gear and move slightly but then just plays up again, we have had lots of snow here for the last week and the dealer said it is possibly something to do with the weather and needs hooking up to the computer and performing a hard re set, any advice?
