Trip Meters and Information Center Buttons Unresponsive...
Before my engine failed on me, I was getting the "35mph Max" fault in the message center. I'm wondering if this would cause for my message center to only show me the odometer reading of my Range, or if there is something else at fault here. I can't get anything else to come up in the message center, whether it be my fuel range, or my trip meters. What could be causing this issue? Could it be the fault set by the EAS? My truck has been converted to coils by the PO, but it still has the air tank underneath I believe. It's been almost a month since I put my hands on the truck, but I'll be back out in Phoenix next Tuesday so I can give her a good going-through to iron out all my issues. Any ideas or suggestions for me?
If the coil conversion was not done correctly, a fault will present itself. The system needs to be set to "manual". I forget the exact procedure but here is an article I found: http://www.tawpark4x4.com/instructions/eas_harness.htm The fault could possibly cause the information center to not respond.
Mine displays "slow to 35mph" and then disappears when the battery is low. Meaning it detects something, and the realizes it was false. You might be right about needing EAS software to clear the fault. However, that is the correct procedure for overriding the EAS system after a coil conversion. You need to do it first before you clear the faults. In the instructions, you are disconnecting the EAS ECU permanently, and temporarily disconnecting the battery. This usually clears all fault codes.
TRIARII
01-21-2015 05:37 PM
Drillbit
05-15-2014 10:58 AM
