What products help preserve your Range Rover?
Old May 27, 2010 | 01:12 AM
RROJ's Avatar
Default What products help preserve your Range Rover?
Items like the dashboard,leather seats,head liner cleaner,outer trim like the door handle which fade in the sun, and the black vinyl in the back quarter panels.
I know there are many products out there but only some really work. I wanted to hear from you all and the products you found are worth buying.
After playing in the mud I would like to cleaner her up, but want to due it right the first time around so I can keep her looking like new for as long as I can polish!
Thanks for reading!
RROJ
Old May 28, 2010 | 09:46 AM
Chris X's Avatar
Leather: Lexol cleaner soap, sponge, bucket of water. Follow up with Zymol leather conditioner.
Dash/plastic bits: McGuire's low sheen stuff. Non greasy, minimizes reflection in the windshield.
Wood: Eagle One Nano spray wax
Outside black trim: clean first with bug and tar and a small detail scrub brush and buff off. Then treat all black with Mothers Back to Black - several coats usually and then buff after applying with microfiber.
Wheels: wax with McGuire's Cleaner wax
Tires: McGuires spray
Engine bay: Simple Green Degreaser
Old May 28, 2010 | 09:11 PM
RROJ's Avatar
Chris X, you are the best! Thank you for saving me years of trial and error. One question the handles to my RR look like they are made of different plastic. The handle is darker than the place where your thumb touches (its so faded). I had treated it with some Turtle Wax vinyl treatment but it washed off and streaked down my black paint. Ugg. Do you think Mothers will treat that piece of plastic or did Mother Nature win again and fade it to no revival?
Old May 28, 2010 | 10:18 PM
LRScott's Avatar
The faded door handles are common on older rovers, especially if they sat out in the sun a lot. Armour All masks it and re-hydrates the plastic, but the only permanent solution is to repaint it with a black plastic paint. I just use Armour All on mine and am too lazy to repaint them .
Old May 28, 2010 | 10:52 PM
lordmorpheus's Avatar
If your black plastic trim pieces have faded to a dull greyish color, the best product I have found (changed my wheel arch moldings from grey to black 2 years ago and they still look great) is:
Forever Black http://www.foreverblack.com/
It is partially a dye, so be careful. I got some on my paint, but it came off with a little elbow grease.
Old May 29, 2010 | 07:48 AM
wilson96rr's Avatar
I like leatherique for the seats. It is expensive but it works very well.
Old May 29, 2010 | 02:09 PM
RROJ's Avatar
Thank you Wilson96rr. I will add it to my RR preserving products collection.
RROJ
Old Jun 2, 2010 | 06:45 AM
Chris X's Avatar
Forever Black cited by lordmorpheus is a grade higher than the Mothers stuff, so it will last longer but you do have to be a little more careful when applying. If your door handles are really really faded and you don't want to repaint them, I would opt for the Forever Black as a more intensive solution. The Mothers works but would require more frequent applications and wouldn't be quite as dark. Mine are not all that bad so the Mothers works for me.
Best of luck!
Old Jun 3, 2010 | 02:15 AM
RROJ's Avatar
Chris X, thank you for clarifying. I will handle the problem very carefully. I don't mind reapplying, but just did not want to each time it rained. Each one of the handles are not faded just the part that ones thumb would hit. Strange. It looks odd so I just wanted to see what others do to solve a similar problem.
Thanks again!
RROJ
SuperiorCarCare
Detailing
Jun 29, 2015 02:38 PM
Beamer1
Apr 20, 2012 01:39 PM
bosshogt
Aug 30, 2010 08:57 PM
thechidz
Feb 9, 2010 03:28 PM
