Wheel Bearing Roaring LIke 747
Old Oct 5, 2009 | 06:21 PM
NiveK1970's Avatar
suspension is good, defiantly in the drive line or axle.
Old Oct 18, 2009 | 02:55 PM
NiveK1970's Avatar
can't get the axle hub nut off, damn thing is on there like crazy glue, can't keep the breaker bar and socket from slipping because of how much pressure I am putting on it, put some penetrating lube on it, gonna let it sit for a while then try again, wonder if I should get a torch and heat it up as well?
Old Oct 18, 2009 | 05:21 PM
handsome rob's Avatar
Heat might help but if you have access to an impact gun you will probably do better.
Old Oct 18, 2009 | 07:24 PM
NiveK1970's Avatar
i took a 500 torq impact gun to it nothing, tried jumping up and down on my breaker bar and nothing, starting to wonder about this
Old Oct 18, 2009 | 07:42 PM
It has been a couple years since I have done but check to se if it is not left hand thread and need to bu turned to the right to loosen it and not the left like normal.
Old Oct 18, 2009 | 08:20 PM
NiveK1970's Avatar
hahah oh damn, i don't know if i could tell that or not
Old Oct 19, 2009 | 10:41 AM
Well, try to turn it the other way. I cannto remember exactly but I think there was something on there that was a reverse thread. It may just even break loose if you can get it to move the other direction.
Old Oct 19, 2009 | 11:33 AM
NiveK1970's Avatar
well after letting it sit all night i went out and hit it this morning with the impact gun and it popped off like it was a water bottle cap , guess it just needed to soak in that lube. Now if UPS will get me my used hub i got on ebay ill stuff it on and see if it still roars like an airplane
Old Oct 19, 2009 | 02:07 PM
Glad to hear it came off fine. I guess that shows what a little patience and time will do for you. Good luck.
Old Nov 23, 2009 | 08:26 AM
NiveK1970's Avatar
well i got underneath it finally, right where the ujoin connects at the rear diff you can move it up and down and here the bearing at the front of that diff bumping, so how hard is it to replace that bearing?
