Sponsored by: CARiD
180k Tune Up
Old Apr 17, 2017 | 03:22 PM
Ursula's Avatar
Default 180k Tune Up
I have some time coming up where I can park m'disco and give her the TLC she deserves. She's getting close to 180K mark on the clock and as I was going to dig in and track down my tick and a leak. I figured I should just get ahead of it and do a tune up.
I have some have big driving planned for the summer.
I have not been able to find a list for the 180K tune up but am making one from just reading what people are replacing at what stage but I would like to stay focused and not waste time and money on whats not necessary.
I'm looking for any advice that would help me get this all planned out so I can order my parts in one go.
The main variable I see at the moment is if my tick ends up being a push rod or along that chain, then I see myself replacing the cam as well. But if its something not as deep then should I still consider replacing the cam if I replace the timing chain?
These are the kind of things I am wondering. Any thoughts would be great!
Old Apr 17, 2017 | 03:43 PM
jlrvkohl's Avatar
well there isnt a scheduled 180k maintenance from landrover for this vehicle, but what i would do is the 120k service if it hasnt had it that you kow of. thats the major one for this vehicle
120k Serivce:
Check parking brake (Adjust if necessary)
Check seat belts
VEHICLE EXTERIOR
1 Add 16 oz Land Rover Fuel Conditioner (LRN5010)
2 Inspect wiper blades
3 Lubricate door locks, check straps, rear end-door hinges,
hood latch and safety catch, fuel door hinges
4 Replace Alarm handset batteries
3 UNDER HOOD
1 Inspect coolant hoses
2 Inspect radiator and AC condenser
3 Check power steering fluid level/ACE fluid level
4 Inspect serpentine drive belt
5 Clean and service battery and terminals
6 Check brake fluid level
7 Change brake fluid
8 Replace air-cleaner element
9 Change engine coolant
10 Replace spark plugs
11 Replace serpentine drive belt
UNDER VEHICLE
1 Inspect tire pressures, condition and tread depth
2 Lubricate wheel centers and install road wheels on same
axle opposite side unless directional tires are fitted
Inspect brake pads, calipers and discs
5 Change engine oil and replace filter
6 Inspect exhaust system and heat shields
7 Inspect brake lines
8 Inspect for free play in propeller shaft universal/sliding joints
and lubricate sliding joints
9 Inspect steering rods, joints and dust covers
10 Inspect shock absorbers
11 Check trailer hitch attachment bolts for tightness
12 Inspect suspension links and mountings
13 Inspect wheel speed sensor and height sensor wiring
14 Inspect fuel and hydraulic lines
15 Change transfer gearbox oil
16 Check front and rear axle oil level
17 Change transmission fluid
18 Replace transmission fluid filter (One-time only)
19 Inspect engine and transmission mounts
20 Check steering box for freeplay
21 Change front and rear axle oil
22 Service ACE filter (If equipped)
23 Service SLS filter (If equipped)
24 Perform road test and endorse Passport to Service
Old Apr 18, 2017 | 12:55 PM
Ursula's Avatar
Thanks! this is a great list.
I am gonna use this list to build my list that I am going to post back here. Would love to get eyes on it to make sure I'm not missing anything or if I am over-planning the tune up.
paul7829
Aug 15, 2006 01:08 PM
paul7829
Aug 15, 2006 12:00 AM
anthonyb
Jul 24, 2006 01:21 PM
disco12
Dec 20, 2005 06:43 AM
winnegar
Sep 27, 2005 12:51 AM
