Sponsored by: CARiD
1990 rover
Old Aug 28, 2007 | 04:39 PM
newbee's Avatar
Default 1990 rover
my master cylinder has a leak on the area where a line to the brakes exits or enters? It's located at the very top to the left, faceing the engine .Is there a seal in that area or did my m.c just go bad.
its not to bad right know but ..sometimes it shoots out a spray of fluid right on to the manafold .talk about a smoking hot rover..ha.ha
Old Aug 29, 2007 | 07:28 AM
Default RE: 1990 rover
I wouldn't drive it for 2 reasons, it shoots out brake fluid, possible failure and if brake fluid hits a hot manifold, you could easily have a fire. Buy a new one and take care of your massive issue. Also make sure you do a complete flush of the system when you ar done.
Old Aug 29, 2007 | 05:40 PM
Adz's Avatar
Adz
If fluid can get out, likely air can get in. Air in the brakes is mui mui mui pelligrosso mi amigo! As Mike said... don't drive it until you've fixed it.
Cheers,
Old Aug 30, 2007 | 04:18 AM
newbee's Avatar
thanks guys.. have a new part on the way... also ordered a new switch from www.roverland.com .. sunroof switch.. 15$ the help that i have found with my new rover family ...priceless.. thanks..
CJsRover137
Jun 14, 2006 05:28 PM
fatmat27
Apr 13, 2006 08:09 PM
CJsRover137
Apr 7, 2006 06:46 PM
lafayette
Nov 14, 2005 10:33 PM
moray
Sep 18, 2005 07:37 PM
