1996 discovery sputters
VSS is the vehicle speed sensor, common problem. The VSS fails intermittently and tells the computer the truck is going like 150 MPH so the computer shuts down a bank of injectors. You need to get it on a scan tool and see if there are any codes stored and post that info. Other common failures are the Mass airflow sensor and sticking exhaust valves causing intermittent misfires. You would need to hook up a vacuum gauge and watch for bouncing vacuum readings when it is acting up to diagnose that. In other words it could be a few different things.
