Sponsored by: CARiD
1996 rangerover
Old Mar 9, 2009 | 07:01 PM
wrhawkins2's Avatar
Default 1996 rangerover
where is idle control valve located?
Old Mar 10, 2009 | 08:23 PM
greg409's Avatar
Do a search for - stepper motor - also called - idle air control - or IAC
it's a small black electric motor with (2) small mounting screws
it's just to the right of your intake plenum (the big black rectangle on top of your engine)
If you're good with tools/mechanics you may proceed to clean it by -
disconnect battery ground
unplug connector
unscrew (2) screws (I use 7/32 socket)
DO NOT mess with or try to turn the shaft!
I spray mine with WD-40 or equiv. and scrub with toothbrush (not my own)
The hole in intake, do the same until it's clean
reinstall
luck, greg
Old Mar 27, 2009 | 08:03 PM
KarenCaren's Avatar
If you like a detailed info. check the forum.
http://www.landroversonly.com/forums...get-know-1843/
I think you will find it useful. Goodluck dude.
___________________
If you ain't first your last!
underbody light kits
feathers
Feb 23, 2013 03:04 PM
rangeroverhse
Jul 23, 2008 08:15 AM
MTGRO30
Sep 3, 2007 08:06 AM
eriklutz
Jul 4, 2006 09:40 AM
landyrangie
Dec 26, 2005 10:20 AM
