Sponsored by: CARiD
1997 DISCOVERY
Old 02-06-2007 | 01:52 PM
RJADM2000's Avatar
Default 1997 DISCOVERY
I HAVE A 1997 DISCOVERY THE ALTERNATOR CHECKED OK ALL LIGHTS ARE PUSATING AND TAC WORKS SPORADICALLY ALTERNATOR WAS CHECKED OUT OF THE CAR BATTERY IS GOOD AND CHARGED AND CONNECTIONS ARE GOOD NEED HELP ALSO NO CODES SHOWING UP
Old 02-06-2007 | 05:34 PM
Default RE: 1997 DISCOVERY
You either have dirty and loose connections or whoever tested the alternator missed something cause it is most likely failing based on what you are describing. Put the alternator back in the truck and get it checked by someone who is more familiar with Rovers.
Mike
Old 02-16-2007 | 01:20 PM
RJADM2000's Avatar
HAD ALT TESTED IN CAR WAS BAD 12 V 16 AMP INSTALLED NEW ONE STILL HAVE SAME PROBLEM TAC AND SPEED GO CRAZY ABS LIGHT COMES ON AND CAR DIES BUT LIGHTS NOT PULSATING WHAT TO DO WILL CHECK CONNECTIONS
adamhannah
08-01-2011 01:41 PM
tymecard
09-27-2005 10:41 PM
charvey
06-25-2005 03:11 PM
vicki
05-12-2005 02:31 PM
Potomac Paddler
10-17-2004 04:42 PM
Quick Reply: 1997 DISCOVERY
