1997 discovery auto won't move in drive
1997 Discovery automatic.
I have a very annoying intermittent problem which leaves me stranded sometimes.
Symptoms:
Won't move forward in drive, particularly when parked on a hill.
Won't idle smoothly when this happens.
Happens more when tank is low but not always.
On flat ground will eventually move when it is warmer, but randomly fails to move in Drive during a journey when I stop at a roundabout or point it toward a hill.
Yesterday it failed to move in Drive at a roundabout and wouldn't even click over. I clicked through the Park, Drive, N, 1,2 and 3 and then it started again and moved a short distance in Drive but then wouldn't move at all, but was running, so I left it where it was and walked to work.
Any clues??![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
![Embarrassment](https://landroverforums.com/forum/images/smilies/r8fZzl5.png)
Symptoms:
Any clues??
Ok so Spike555 I did like you said. When I drove to work yesterday I was normal until I got outside work on a hill and it decided to not move forward, so I put it in 1st and it worked. This morning when I finished work it didn't want to move right from the start.....but it did in 1st.
So what do you reckon? Thanks for getting back to me.
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
Your shift linkage needs to be adjusted, when you think you are in drive you are actually half way between neutral and drive so the transmission is slipping when under load because it is not fully in gear.
Pop the trim piece off of the top of the gear shift ****, inside should be a nut, with the shifter in park tighten that nut.
Experiment with the tightness until the transmission acts and shifts the way you feel is normal.
