Sponsored by: CARiD
1998 Disco Power Steering Gear Box Leak
Old Aug 2, 2016 | 06:48 PM
DavidR's Avatar
Default 1998 Disco Power Steering Gear Box Leak
Bought a 1998 Disco I about a year ago. Had power steering leak when I purchased it. Just fed it with fluid until it got worse about a month ago. Decided to clean all the gunk off it with a power washer and find the leak. When I did I was able to find the leak. It is on the gear box on one bolt. Tried tightening it. No dice.
Any advice on how to repair it? Preferably without ripping the whole gear box out and replacing it. Is there a gasket I can pull and replace?
Here are a few pictures
Top view of gear box. Bolt leaking is the one on the left.
Picture of leaking bolt.
Old Aug 2, 2016 | 09:56 PM
XCELLER8's Avatar
from my experience with that similar situation....if you remove the top four bolts , and the center adjuster...that top piece is sealed with an o-ring>>>>and it needs to be the RIGHT o-ring....search for a seal kit for the box and usually that o ring is included ...but not listed separately on most of the popular parts sites
Old Aug 9, 2016 | 09:43 PM
Clay99d2's Avatar
Default Rovahfarm
Call Trevor at rovafarm.com. He will get sell you the right O-ring or find you someone who can.
Old Aug 10, 2016 | 04:45 AM
loanrangie's Avatar
I think from memory its a square section seal so not a normal o-ring.
Old Aug 31, 2016 | 07:14 AM
DavidR's Avatar
Thanks for all the info. Bought a seal kit and began taking the top of the gear box apart (while installed in the vehicle). It was not easy. Not sure who worked on it last but those four bolts must have been put on with an impact wrench.
Now I am unable to pull that top plate to change the o-ring. I tried consulting the great youtube and it looks like you might have to unbolt the bolt to the drop arm and pull the whole shaft assmbly out.
Any thoughts?
Old Aug 31, 2016 | 07:33 AM
RedRovin''s Avatar
You shouldn't have to drop the Pitman arm to remove the lid. Use a hex key to rotate the stud on top. Count your turns and reverse for install.
The stud is attached but free floating on the shaft inside. Essentially the cover screws on to the stud. Hope that makes sense.
Old Aug 31, 2016 | 05:21 PM
DavidR's Avatar
Makes sense I loosened it but the cover won't rotate. I take it with how tight the four bolts were it could jus be on siezed up. I'll keep working at it. Thanks
Old Sep 1, 2016 | 10:57 AM
DavidR's Avatar
Was unable to remove the plate. It won't budge.
Old Sep 1, 2016 | 11:59 PM
number9's Avatar
Overhaul info in D1 manual, Rave download.
Old Sep 2, 2016 | 02:29 AM
number9's Avatar
Hear you go.
6. Remove set screw retaining rack pad adjuster.
7. Remove rack adjuster and pad.
8. Remove sector shaft adjuster locknut.
9. Remove four bolts from sector shaft cover.
10. Screw in sector shaft adjuster until cover is
removed.
File Type: pdf
