Sponsored by: CARiD
1998 Discovery LE,, 4.0 engine,, 137,000 miles
Old Oct 8, 2016 | 01:29 PM
DamenTech's Avatar
Default 1998 Discovery LE,, 4.0 engine,, 137,000 miles
I have battery voltage at TPS -- Temp pressure sensor --- Engine coolant sensor --- MAF sensor at the Red/black wire for each sensor.. This voltage disappears if I diconnect the cam sensor....which also has the same Red/black wire.... Please help me diagnose by providing a wiring diagram of camshaft sensor to determine what values should be at each wire. Vehicle starts but runs super rich... With high idle... With no check engine lite..
Thanks in Advance for any help!!!
Old Oct 8, 2016 | 09:42 PM
XCELLER8's Avatar
there have been quite a few of these "advanced evap" vehicles with this issue, some of us have found that the culprit is the fuel tank pressure sensor ( or the wiring to it ) ..it shares the same voltage feed as the tps,and the iacv.... iirc....and any fault in THAT circuit will mess with the fuel ratio/ delivery. roll up the carpet in back to get acccess to the fuel pump and unplug the sensor on he top of the pump assy....my truck INSTANTLY ran normal after the unplug
Old Oct 10, 2016 | 09:34 AM
WaltNYC's Avatar
check out post #3 in this thread.
the entire thread is likely to save you many many hours of anguish.
Welcome to the club.
https://landroverforums.com/forum/di...02/#post581013
Old Oct 11, 2016 | 10:40 AM
DamenTech's Avatar
Thanks for the speedy response,,,, Unfortunately this did'nt work....Only when we disconnect the camshaft sensor connector does the battery voltage leave the other sensors connectors,,,,, tps,,, iac... maf...etc... I have no luck so far in gettng a wiring diagram to determine where the wires go or their values......
Old Oct 11, 2016 | 02:04 PM
WaltNYC's Avatar
2nd try...
Click on this link. Follow the link in that post. Download the electrical trouble shooting manual. Read diagram.
https://landroverforums.com/forum/di...02/#post536729
Bookmark that thread because if you own a D1 there is no better source of information anywhere else on the interwebs.
Old Oct 12, 2016 | 01:07 PM
DamenTech's Avatar
Default Thanks,,,,, the fix
**** The fix was ,,, The problem was the R/B wire should have been system ground and the ground integrity was not good!!!!
Old Oct 12, 2016 | 01:10 PM
DamenTech's Avatar
This 1998 Land Rover 4.0 engine will not idle under 1100 rpm and all sensors are reading within specs.... Any ideas ?
Old Nov 8, 2016 | 01:50 PM
DamenTech's Avatar
I was unable to open to read..... Also I tried downloading a link that you posted for a wiring diagram of ECM pin-out..... Really appreciate if you have other resources to send... Thanks in advance......
Old Nov 8, 2016 | 01:52 PM
DamenTech's Avatar
Originally Posted by WaltNYC
2nd try...
Old Nov 8, 2016 | 02:14 PM
DamenTech's Avatar
Could not open link,,,,, is there another way for me to get these diagrams or information. Really appreciate your help..... On another post I open & downloaded electrical information, but it only had flow charts & no wiring diagrams..... Thanks again,,,
