1999 disco II interior light problem
interior lights wont go on, or off with doors, you can put them on door mode but then they just stay on the whole time driving and do the 8 min time out thing once parked. everything else works fine.
the whole bcu doesnt need replacing does it?
Welcome aboard !
Just to clarify, your interior lights can be manually switched on and off via switch ? But in door mode they stay on until they time out, regardless if any door is open or shut.
Correct ?
Correct ?
ORIGINAL: Bait
Welcome aboard !
Correct ?
Welcome aboard !
Correct ?
correct. and then after the 8 min time out. they will not turn on when in door mode at all till the next start up and shut down cycle.
any ideas?
afs244
Apr 24, 2013 04:40 AM
