Sponsored by: CARiD
1999 Discovery series I Distributor Cap/Rotor?!...shock absorbers?!
Old Feb 28, 2016 | 08:06 AM
Tonyfnb's Avatar
Default 1999 Discovery series I Distributor Cap/Rotor?!...shock absorbers?!
Took my LR in for a tune up bc its sat for a while...and quickly took it out when I heard just the plugs part of the tune up would be $200...anyways they have on my list that I need a new Distributor Cap & Rotor...UHHH WHERE IN THE WORLD DO I FIND THIS?! I know I read to go OEM...I'm on RockAuto but I don't know which one of these looks like mine? Please help!
I figured out the shocks
Old Feb 28, 2016 | 08:29 AM
robertf's Avatar
does your intake manifold say 3.9 or 4.0?
Old Feb 28, 2016 | 08:50 AM
Tonyfnb's Avatar
It says 4.0
Old Feb 28, 2016 | 09:40 AM
robertf's Avatar
you need a new mechanic. 4.0 doesnt have a distributor
Old Feb 28, 2016 | 10:20 AM
binvanna's Avatar
The '99 just needs spark plugs and wires, when it does (but not necessarily just because). It uses electronic ignition and a coil-pack on the back of the intake manifold. You can search the D1 section for recommendations on the plugs and wires. There's a couple options that are recommended.
Old Feb 28, 2016 | 12:21 PM
Tonyfnb's Avatar
WOW! Tuffy's here told me that......
Old Feb 28, 2016 | 02:44 PM
drowssap's Avatar
Distbutor-less ignition.
Old Feb 28, 2016 | 02:54 PM
Tonyfnb's Avatar
Is that something I should know? Sorry I know nothing about any of this
Old Feb 29, 2016 | 09:40 AM
Paul Grant's Avatar
Tonyfnb, are you in the US or somewhere else in the world? I know you said you were looking on the Rockauto website but that doesn't necessarily mean you're in the US. I ask because other parts of the world never saw the GEMS fuel injection system that was in the US DI models from 1996-1999. In your profile, there's a way for you to enter your location so people offering advice don't have to guess where you are. Look at Drowssap's posts and you'll see he's in Boston, I'm in CT. It can really help people offering advice.
Now, if, in fact you are in the US, run, don't walk away from the mechanic that told you you have a distributor. As Drowssap said, you have a distributorless ignition system. The fuel injection system you should have in your vehicle is called GEMS and stands for Generic Engine Management System. It was the first OBDII fuel injection system Rover offered. It was mandated by US regulations. Other parts of the world did not require OBDII compliance until years later. That's why I say that some parts of the work never even saw GEMS. They went straight from the older Lucas 14CUX fuel injection system (OBDI compliant AND using a distributor) to the Bosch (OBDII distributorless) system.
Old Feb 29, 2016 | 09:51 AM
drowssap's Avatar
thanks for the lesson
