Sponsored by: CARiD
1999 Range Rover 4.6 HSE
Old Apr 30, 2008 | 12:49 AM
scott222's Avatar
Default 1999 Range Rover 4.6 HSE
I need some help. I have this smell in my car that seems like it is anti freeze that is disapating. It is either exhaust or something, that appears to be coming through the vents. Basically, if i drive 5 minutes, my clothes smell etc. I took it to the mechanic and he couldnt find any leaks in the cooling system. Evidently there is a small radiator under the glove box, but he said that was not leaking. I really don't know what it could be, but my wife is bugging about the smell.
Any thoughts?
Thanks,
Scott
Old Apr 30, 2008 | 07:24 AM
Default RE: 1999 Range Rover 4.6 HSE
Go take it to some one other then the one you have already tried and have a standard coolant pressure test performed, this will help a good mechanic find your coolant leak.
Old Apr 30, 2008 | 12:56 PM
scott222's Avatar
Thanks, very much appreciated, can you recommend a mechanic in the Costa Mesa/Irvine area?
Old Apr 30, 2008 | 01:07 PM
Even a good radiator shop can do this test.
Let me know the results.
Old May 3, 2008 | 11:21 PM
lrobin3w's Avatar
leaking heater core o-ring seals are common and will not always show up with a coolant pressure test! Look under the pass side of the center console area, for visable small leaks.
Cottrell
Nov 20, 2012 07:46 PM
ddemars
Sep 8, 2009 12:44 AM
omaromarvasquez
Feb 19, 2009 06:37 PM
krazyoljim
Sep 7, 2008 10:04 PM
Jim99
Oct 27, 2006 07:14 PM
