Sponsored by: CARiD
2 battery wiring question
Old Aug 19, 2015 | 05:27 PM
antichrist's Avatar
Originally Posted by Roverfanatic
Holy moly! I actually accidentally bought the correct one!
Cool. I'm curious what it cost you.
Uh... so does the wiring look right?
I'm not sure exactly what you're wanting to do. 30amp capacity isn't very much for connecting two batteries (I'm assuming one use would be if your starting battery is drained and you need to jump it with the winch battery, or vice versa).
I'd use a 200 amp continuous duty solenoid, like a Cole Hersee
Cole Hersee - 200a continuous duty
PN 24143 - Silver contacts
replaced by
PN 24213 - Silver Tungsten Contacts
Solenoid continuous 4pole 12v carbide, 24213, Cole Hersee - Ryder Fleet Products
http://www.colehersee.com/assets/fil...5Solenoids.pdf
Old Aug 19, 2015 | 05:45 PM
antichrist's Avatar
Actually, come to think of it, why do you want the relay closed when the engine is running? That's when the alternator would be charging both batteries.
Old Aug 19, 2015 | 05:59 PM
Roverfanatic's Avatar
Won't it still be charging through the isolator when runnning?
Old Aug 19, 2015 | 06:00 PM
I paid 24.00on Ebay for the Isolator....
Old Aug 19, 2015 | 06:48 PM
hummm...
Car running.....solenoid not activated......isolator determining which battery to charge....2 battery system not in parellel..."isolated" from one another
car running.....solenoid not active....isolator determining which battery to charge...main battery bad....attempt restart...fail...activate solenoid...batteries now in parallel...car start ...pass
car running....solenoid not active....isolator determining which battery to charge....2 battery system not in parallel...activate winch....load only on main battery....activate solenoid...2 battery system in parallel....activate winch....load on main and aux in parallel.
There are someother senario's but, that conveys the point....I think...
Old Aug 19, 2015 | 10:55 PM
antichrist's Avatar
Yes, that's why I don't know why you want the relay closed with the engine running, it serves no purpose that I can see.
Ok, yeah, then you definitely don't want a 30amp relay in there.
$24 is a damn good price for a 160amp Sure Power Schottky diode Isolator. I assume it's used. Be sure to test it as soon as you get it. I bought a used one off ebay years ago and didn't do that. 6 months or a year later when i went to hook it up, it was not working on one of the posts.
Old Aug 19, 2015 | 11:08 PM
It's going in as soon as I get it already have the the pre wiring done so I will test it that day....keeping fingers crossed...
Old Aug 20, 2015 | 12:47 PM
antichrist's Avatar
Sounds good, just be sure to not leave feedback until you've tested it. Once you do you can't open an ebay defect.
Old Aug 20, 2015 | 03:48 PM
june82000's Avatar
Bring a fire extinguisher just in case
Old Aug 21, 2015 | 12:26 PM
That would be funny if it wasnt so possible with me!
I just received the isolator in the mail...brand new in the box...unopened! Not sure why but I'll take it...
