Sponsored by: CARiD
2001 Disco II Idle Question
Old Aug 18, 2008 | 11:57 AM
NYDISCO's Avatar
Default 2001 Disco II Idle Question
Just replaced the coil pack on a 2001 (What fun!) - after buttoning it back up the normal idle up process it usually does with a cold startbefore settling down to normal idle is not functioning... Any thoughts on what may have done this? Basically now I just have to give it a little gas when starting.
Thanks!
Old Aug 18, 2008 | 03:09 PM
Default RE: 2001 Disco II Idle Question
Inspect both you throttle cables and clean the inside of the t/body. If that doesn't fix it, get back to me.
Old Aug 18, 2008 | 03:22 PM
NYDISCO's Avatar
I actually looked everything over pretty well last night and could not see anything out of the ordinary. How does this "electronic choke" of sorts work? Is there an actuator on one of those cables?(The only one I saw I assumed was for the cruise)... I did have to pull the top manifold off and did replace the gasket when putting everything backtogether... I can't think of anything else it could be besides it being electrical related..
Thanks Mike!
Old Aug 18, 2008 | 05:08 PM
NYDISCO's Avatar
Mike.. I just went out and cleaned the sh&t out of the TB ..it did have a little goo in it.. (120k worth) - it does seem to idle a tad higher now than before.. the test will be in the morning with a cold start.... Thanks!!!
Old Aug 19, 2008 | 07:15 AM
NYDISCO's Avatar
This morning with a cold start it seemed a little better, but not 100%.. Should I pull off the stepper-motor idle valve and give that a cleaning?
Old Aug 19, 2008 | 08:32 AM
PM me your tele number and I will call you and walk you thru cleaning the idle control.
wick_60010
Nov 22, 2017 04:25 AM
KGN96discoSE7
Sep 23, 2017 07:23 AM
johnkbl
Jan 19, 2010 05:22 AM
eurosport1
Nov 25, 2008 03:02 PM
westernsun
May 27, 2006 04:24 PM
