2001 Discover II SE, Vibration at 60-70 mph
RE: 2001 Discover II SE, Vibration at 60-70 mph
Have you checked the obvious tire balance and air pressure?
Next thing I would check is the front drive shaft, the constant velocity joints are known to fail because they came from the factory without grease fittings. If your don't have grease fittings have new u-jonts installed.
Mike
Mike
