Sponsored by: CARiD
2001 discovery 2
Old 11-27-2021 | 06:14 PM
Travis James's Avatar
5th Gear
Default 2001 discovery 2
Hello all,
I acquired a 2001 discovery 2 a couple years ago.. I've been very happy with it.. along the way I've had issues mostly small.. however the gauge or cluster doesn't work.. I'm thinking it's a ground but I'm not sure.. the cluster lights up but the needles do nothing.. I found a what appears to be a ground wire underneath the steering wheel that is ripped off of it's eyelet... I'm not sure where the wire is located or if it's factory original.. the eyelet is the only thing remaining I can't locate the wire that was attached to it.. any help would be appreciated
Old 11-27-2021 | 10:13 PM
Harvlr's Avatar
Try posting in the Discovery 2 part of this forum and add a photo.
Travis James (11-27-2021)
Old 12-16-2021 | 03:18 PM
tydenioluwa's Avatar
Originally Posted by Travis James
Hello all,
welcome can you put some photos ?
شقق للبيع في اسطنبول
Old 02-28-2022 | 05:21 PM
5th Gear
Okay so I was finally able to check to see if the dummies lights came on.. they did not.. so I'm guessing this would be a ground issue?
blackcatphil
07-02-2014 06:11 PM
bustedwheel
02-01-2012 08:11 PM
wheelgarage
07-14-2011 09:51 AM
ajh
10-04-2007 09:44 AM
coldfrez
10-01-2007 10:49 AM
