Sponsored by: CARiD
2001 discovery 2
Old Nov 27, 2021 | 05:14 PM
Travis James's Avatar
5th Gear
Default 2001 discovery 2
Hello all,
I acquired a 2001 discovery 2 a couple years ago.. I've been very happy with it.. along the way I've had issues mostly small.. however the gauge or cluster doesn't work.. I'm thinking it's a ground but I'm not sure.. the cluster lights up but the needles do nothing.. I found a what appears to be a ground wire underneath the steering wheel that is ripped off of it's eyelet... I'm not sure where the wire is located or if it's factory original.. the eyelet is the only thing remaining I can't locate the wire that was attached to it.. any help would be appreciated
Old Nov 27, 2021 | 09:13 PM
Harvlr's Avatar
Try posting in the Discovery 2 part of this forum and add a photo.
Old Dec 16, 2021 | 02:18 PM
tydenioluwa's Avatar
Originally Posted by Travis James
Hello all,
welcome can you put some photos ?
شقق للبيع في اسطنبول
Old Feb 28, 2022 | 04:21 PM
5th Gear
Okay so I was finally able to check to see if the dummies lights came on.. they did not.. so I'm guessing this would be a ground issue?
blackcatphil
Jul 2, 2014 05:11 PM
bustedwheel
Feb 1, 2012 07:11 PM
wheelgarage
Jul 14, 2011 08:51 AM
ajh
Oct 4, 2007 08:44 AM
coldfrez
Oct 1, 2007 09:49 AM
