2001 Discovery Misfire 1 and 6 need help
Old 03-08-2016, 08:30 PM
Charlie_V's Avatar
Originally Posted by Elliemcqueen
Yay! That worked. The only one left is KOER fail. Do you know what that one is?
I'm stumped. KOER means Key on/Engine running to me (not a joke... I've heard that before) but I've never seen that anywhere in or on my Disco. Is that a code your reader gave you? Where is that coming from?
Old 03-09-2016, 10:47 AM
Elliemcqueen's Avatar
Its a code from safety and emissions test. I was told that bc of the misfire it kept the check engine light on. It should turn off after I have it reset. Thank you so much for all of your help!!
Old 03-09-2016, 10:56 AM
Charlie_V's Avatar
Oh, a sneaky emissions test code. Yep, reset it and you should be good to go.
If you don't have a code reader that reset codes well, shame on you because you have a land Rover and every land Rover owner needs one! But you can just disconnect the battery and tie the positive and negative connectors together with a zip tie or tape (be sure they don't touch the battery) for a few hours to drain any capacitors and it will be like new when you reconnect it all. Good luck!
Elliemcqueen (03-10-2016)
Old 03-10-2016, 08:07 PM
I got a code reader and reset the codes. I am now getting a P1590 ABS rough road signal circuit malfunction. Possible causes: Faulty ABS Control Module, Faulty ABS Control Module Wiring/Connector, Faulty ECM Wiring/Connector. Do you know what this code is or how to fix it? I haven't found anything.
Old 03-11-2016, 07:36 AM
drowssap's Avatar
p1590 rough road signal is how i found my bad hub, might want to check them.
Old 03-11-2016, 07:54 AM
Charlie_V's Avatar
I second that. Only way I got 1590 to go away was with new hubs, even after replacing the ABS sensors.
drowssap (03-11-2016)
BamaDisco2
02-04-2016 09:27 PM
Gromeo
01-24-2013 03:41 PM
LRScott
04-17-2010 09:32 PM
johnkbl
01-19-2010 05:22 AM
tunernewb92
10-20-2009 07:15 PM
Quick Reply: 2001 Discovery Misfire 1 and 6 need help
