Sponsored by: CARiD
2001 landrover disco 2
Old Oct 28, 2010 | 05:14 PM
buellrod's Avatar
Default 2001 landrover disco 2
93,000 i had to replace motor headgasket and severe overheat. All the motors on the eastcoast had high miles found motor in California with secondary air injection which mine does not have installed motor and plugged the ports on exhaust manifolds motor started did not run right took it for a spin for about 20 minutes fresh gas and it ran alittle better got to a light she stalled and that's it. got it running and its pulling 14 codes some i know are ok the guy said that the California motor might have different timing and my computer is not compatible.Can somebody help??
Old Oct 28, 2010 | 05:24 PM
Your computer is fine for that engine. What codes did you find? Clear them and see what fresh codes are there and give us the code numbers.
Old Oct 29, 2010 | 08:29 AM
messar's Avatar
8th Gear
Did you re-set the adaptive values in the engine ECU? You need a faultmate, t4, autologic to do this.
Matt
Amy Roberts
May 29, 2015 09:56 PM
Hmiser9878
Jun 6, 2013 10:21 AM
JamesChristo
Jul 9, 2012 08:38 AM
Thatdudeuno1
Apr 5, 2012 10:54 AM
DISCO24
Mar 15, 2011 07:19 PM
