Sponsored by: CARiD
2003 Disco II Multiple Warning Lights On
Old Jul 19, 2018 | 06:35 AM
Lil Beast's Avatar
7th Gear
Default 2003 Disco II Multiple Warning Lights On
Started my vehicle and multiple warning lights stayed on . Running fine and driving fine. Any ideas????
Old Jul 19, 2018 | 08:21 AM
Sixpack577's Avatar
Yeah
Check and see which codes it has
Old Jul 19, 2018 | 02:43 PM
and which warning lights would help to
Old Jul 20, 2018 | 09:15 AM
Lil Beast's Avatar
7th Gear
Default S & M lights blinking along with the D on the gear shift
Funny enough the problem with the "multiple warning lights stayed on" went away the next time I drove the vehicle. This morning the S & M lights started flashing along with the D on the gear shift. I parked it at work and now it won't start - starter cranks but engine will not turn over. Any thoughts before I call a tow truck on Monday morning - my shop doesn't do weekends.
Old Jul 27, 2018 | 03:41 AM
The Deputy's Avatar
Check your battery connections, must be clean and tight. Also, check ground cable connection at alternator bracket, must be the same. Have battery load tested, if all connections are okay...and have them check the charging system while they are at it.
Brian.
Old Sep 1, 2018 | 10:01 AM
Lil Beast's Avatar
7th Gear
Thank all for the suggestions. It ended up being the crankshaft position sensor.
metzdmichael
Oct 11, 2019 04:41 PM
Lil Beast
Jul 20, 2018 09:56 AM
leeb2761
May 28, 2009 07:42 AM
ablerover
Jun 23, 2008 09:11 PM
