Sponsored by: CARiD
2003 Land Rover (Disco SE7) Sound system issues....
Old Dec 29, 2008 | 10:58 PM
DiscoMike2003's Avatar
Default 2003 Land Rover (Disco SE7) Sound system issues....
Screech when system is powered on, Rear door speakers do not work, looks like the FR door speaker is blown now, woofers in the back seem to work, mabye not as well as they ought to...
Crutchfield says the size is off, so i'm considering figuring out what size woofer to replace it with off maybe partsexpress or something.
Is it likely that i have a problem with the amplifier??
BTW i have the SE7 with cd changer.
What size woofers does it take in the doors??, should i check the signal wires, can i take said speakers out without removal of the door panels??
Any help is good help.
Thanks,
Old Dec 30, 2008 | 05:52 AM
rinmud's Avatar
Default RE: 2003 Land Rover (Disco SE7) Sound system issues....
I cant remember the size we just pulled them out of the box and crammed them in. The panel needs to come off. The biggest problem with the speakers is water. The plastic shield behind the speaker fails and the water flows in and the voice coil seizes up. Pull the panel and remove one (passenger side) that way perfect match on size and OHMs. scott
Abrams101
Jul 21, 2015 06:33 PM
gregstil7
Jan 30, 2012 07:22 PM
Gumper
Apr 12, 2010 01:41 PM
hasty10805
May 9, 2007 10:22 PM
abikepeddler
Jun 13, 2005 05:17 PM
