Sponsored by: CARiD
2003 Land Rover Discovery Series 2 Overheating
Old Mar 7, 2020 | 03:09 PM
Scott Spencer's Avatar
Default 2003 Land Rover Discovery Series 2 Overheating
Hello I have a Land Rover Discovery Series 2 that is that starts to overheat after 20-30 minutes after running the cooling system seems to be running the way it should I replaced the thermostat (which didn’t work) I can’t detect any leaks anywhere and I see no signs that would point to a blown head gasket any thoughts? Thanks in advance
Old Mar 7, 2020 | 03:33 PM
mollusc's Avatar
Read the Discovery 2 forum on here. Plenty of discussion of all of the possible causes of D2's overheating.
Old Mar 7, 2020 | 04:42 PM
No Doubt's Avatar
Common Disco 2 overheating problems include:
Low/bad engine oil
Failing fan clutch
bad thermostat
clogged radiator or debris covering radiator fins
Low coolant
Failing waterpump
headgasket failure
jcolyar
Other
Mar 1, 2018 10:45 AM
scol354412
Aug 13, 2014 10:16 AM
jmanborges
ROAMING WITH FRIENDS
Oct 3, 2012 09:50 AM
SeriesDude69
Other
Oct 27, 2009 10:59 AM
td4243
Apr 26, 2007 12:46 AM
