Sponsored by: CARiD
2005 RR Susp.Problem
Old Sep 16, 2013 | 02:41 PM
wm1965's Avatar
Default 2005 RR Susp.Problem
Hi everyone. I have a 2005 Range Rover HSE with 84.000 mi. In the morning I find the suspension has dropped around 1.5 inches all around except the right front goes down 2.5 inches. Once I start the vehicle, the suspension goes back to normal height (29 inches) and stays that way all day. My mechanic told me that this is normal but I did not have this problem before changing the right strut and the 2 front sensors. Once I replaced the right front air strut, I started having problems and the suspension started dropping from one day to the next. I'm thinking I should replace the other front strut (left). Does anyone know if it's normal that the suspension drops more or less 2 inches overnight?
Thanks for your help!
Old Sep 16, 2013 | 05:15 PM
LR Techniker's Avatar
Overnight, it shouldn't drop at all.
First thing that comes to mind, is the fact that you replaced the sensors. Did you have the system re-calibrated? This should be done ANY time a sensor is replaced and unfortunately, requires a high end scan tool, or factory computer.
To see if its an air leak, park the vehicle, then disconnect the battery. If a strut is leaking, then ONLY that corner will drop down, and thats the corner you need to concentrate on. Since the strut is new, if you verify it is leaking, try spraying the connections with soapy water. Perhaps you just didn't get a good connection.
Old Sep 16, 2013 | 05:35 PM
wm1965's Avatar
Thumbs up
Thanks for your quick response. As far as I know, they did recalibrate the system after I changed the sensors. However, I am going to try your other suggestion out and reach out to you with feedback. Thanks again.
roverrick
Feb 4, 2008 07:36 PM
roverrick
Jan 8, 2008 01:22 PM
roverrick
Jan 8, 2008 01:10 PM
OzRRS
Mar 29, 2006 11:16 PM
JRdisco1
Feb 10, 2006 12:34 PM
