Sponsored by: CARiD
2005 td5 defender running rough when hot ???
Old Jan 1, 2013 | 04:06 PM
zander's Avatar
Default 2005 td5 defender running rough when hot ???
Hi all ive just bought a 2005 defender 110 hardtop td5 the car is running as sweet as a nut when it first starts up but as soon as it heats up it starts to run like a bag of spanners but only on tick over then if you let it cool down it runs fine again?? drives fine and got plenty power ect. any ideas anybody??? any help would be much appreciated.
Alex.
Old Jan 1, 2013 | 05:26 PM
Speak English man!!!
Have you checked for coolant loss?
Is the fan clutch working properly?
I assume the temp gauge stays in the normal range?
Have you hooked up a live data scanner to see the actual engine temp?
It sounds to me as if it is just plain old getting to hot for whatever reason.
I'm not sure where the thermostat is located on this thing (we dont have diesels here in the US)
Old Jan 1, 2013 | 05:52 PM
zander's Avatar
thanks for reply spike coolant level is fine and according to gauge its not over heating i must get it onto a computer to find out if it is. When the gauge goes to its highest point the engine makes a loud cluncking noise when its ticking over but if it is revved it sounds fine??
Old Jan 1, 2013 | 06:06 PM
Will it overheat if you let it?
It should never get hot enough to get the gauge past the half way mark.
That clunking sound you hear is the oil getting to thin because it is to hot.
Start checking the cooling system for problems, do a coolant flush, replace the thermostat.
It is def overheating.
dillhole
Feb 20, 2020 02:30 PM
JoeM5952
Feb 12, 2013 08:32 AM
kae
Aug 18, 2009 10:52 AM
abbottz
Mar 9, 2007 10:17 AM
trini defender
Defender
Dec 11, 2006 05:14 AM
