2012 range rover sport won't start after battery swap.
recently changed battery in my 2012 rr sport. When I try to start I get abs, transmission, stability,parking break ect. Warnings. But no start. I have bench+ relay bypass tested the starter. I have done a reset with battery cables. Tried in neutral ,tried gas pedal trick. With torque I get steering sensor abs, brake position codes. Was running fine with no codes before battery change. Have looked at the entire internet 😁 hope y'all can help
Now the car doesn't turn. There is a clicking sound coming from the glovebox (there is a fuse box there) when anything electrical is turned on in the car like the lights. Also, the lights and electronics turn on and off with the clicking sound - it only happens when there is a sufficient charge to the battery (1 light doesn't do it, but having 2 on makes it click or a single major Tutuapp 9Apps Showbox one).
steveopaul
04-18-2021 10:01 AM
cdebari
06-02-2011 12:56 AM
