Sponsored by: CARiD
300 TDI clutch problem
Old Feb 10, 2007 | 01:59 PM
knickerlott's Avatar
3rd Gear
Default 300 TDI clutch problem
Driving home today, put the clutch in and the peddle stayed in without disenguaging the engine? managed to drive it home by starting it in gear and ramming it into each gear, any ideas guys????
Old Feb 13, 2007 | 08:33 PM
geoman's Avatar
Default RE: 300 TDI clutch problem
Assuming you have hydraulic clutch actuation on the300 TDIsuch as the NAM Discovery and Defender90 ---then you have lost hydraulic pressure due to the master cylinder, slave cylinder, or flexible hose letting go. That's why the pedal stays on the floor, and there is no mechanical action imparted to disengage the clutch.
Geoman
Old Feb 18, 2007 | 03:01 PM
3rd Gear
Hi, Geoman. Yes you are right. Somehow the slave cylinder had actually come loose and fell out. I fitted a new one and had a nightmare bleeding it but managed it in the end. Thanks anyway
dirkha
Feb 10, 2021 06:44 AM
Discomadman
May 14, 2011 02:35 AM
shampro
Audio/Visual Electronics
Aug 23, 2009 09:21 PM
sesese
Aug 9, 2009 02:23 PM
teletechlpi
Nov 6, 2006 09:04 PM
