Sponsored by: CARiD
300 tdi defi zd rpm reading...
Old Nov 21, 2016 | 12:11 PM
alpaytufan's Avatar
5th Gear
Default 300 tdi defi zd rpm reading...
Hi . I have disco 1 300 tdi... I attached a defi zd for temps , turbo pressure etc. Most of sensors work properly. I tried to connect rpm from alternateur the result : car shows 700 rpm ... defi shows 3200-3300 rpm ... how I can reduce this signal comming from alternateur???
Thank's
Old Nov 25, 2016 | 04:55 PM
loanrangie's Avatar
I havent heard of the Defi before but i would expect that there is a way to change the settings, did you attach the feed to factory tach feed wire ?
Old Nov 29, 2016 | 02:35 AM
alpaytufan's Avatar
5th Gear
Yes ...
I connected wire from alternator to dvice... even the divece set to maximum ( v8-11000) I read 3300 rpm on device when engin run's at 550-700 rpm...
dirkha
Feb 10, 2021 06:44 AM
alpaytufan
Nov 20, 2016 11:20 AM
shampro
Audio/Visual Electronics
Aug 23, 2009 09:21 PM
sesese
Aug 9, 2009 02:23 PM
teletechlpi
Nov 6, 2006 09:04 PM
