Sponsored by: CARiD
93 defender 110 heated windsheild timer
Old Feb 28, 2007 | 11:40 AM
Sport4Auto's Avatar
4wd High
Default 93 defender 110 heated windsheild timer
The heated windsheild is not working, when you push the switch and the timer turns off the relay as soon as you let go of the button. how long should the timer keep the relay on. is it possible the timer is bad.
Old Mar 10, 2007 | 08:54 AM
mymini67's Avatar
Default RE: 93 defender 110 heated windsheild timer
Hi,
the timer should run for about 10 mins. Check the voltage at the input to the timer because there is a voltage sensitive relay in the cct too! If its below 11.5 v (ish) it wont let the heater work.
Hope this is of some help.
Miguel Angel de la Cueva
Defender
May 9, 2024 02:59 AM
knightmetro
Nov 1, 2014 04:53 AM
Mar 19, 2013 02:20 PM
krazzz
Dec 1, 2009 10:21 AM
fire1427
Sep 19, 2007 07:59 PM
