Sponsored by: CARiD
93 disco getting hot.
Old Aug 17, 2015 | 06:53 AM
Kiwijeff's Avatar
Default 93 disco getting hot.
My new old 93 disco gets a little hot.
The previous owner told me it gets quite hot, but didn't seem concerned about it. He knows cars, but I'm about to take it on a 400 mile trip, and wondered if these engines, V8 are supposed to run hot, and if not, any suggestions?
I think if it was something simple like flushing the radiator, he would have done it.
Thanks, Jeff.
Old Aug 17, 2015 | 07:15 AM
drowssap's Avatar
fulsh the radiator and change the t-stat would be the first $25.00 i would spend
Old Aug 17, 2015 | 07:19 AM
Kiwijeff's Avatar
Thanks, I'll start with that, and see what happens.
Old Aug 17, 2015 | 09:59 PM
june82000's Avatar
Originally Posted by chubbs878
Hey, if you don't have any kind of gauge to view your real-time coolant temps, I would at least buy an OBD scanner that will show live data so that you know exactly where you are on your temp, especially if road-tripping. This is the single most important thing with the discovery besides keeping oil in the engine, if you didn't already know. These things already run hot from the factory and therefore blow head gaskets, radiator hoses, reservoir caps and everything else after they get a few miles on them. You don't want to be running much hotter than 200 if you can help it or else you will start hearing cylinder sleeves pinging if you don't already have that
It's a '93; pre-OBDii. He could get a manual temp gauge for now. If you change the thermostat, 180* is what everybody recommends.
Old Aug 17, 2015 | 10:01 PM
chubbs878's Avatar
Ya I know I thought I read 03. I was trying to delete. Different sitch!
Old Aug 17, 2015 | 10:05 PM
june82000's Avatar
No worries:-)
OP, so where's the needle?
Old Aug 18, 2015 | 01:07 AM
Joe Btfsplik's Avatar
Just a thought, these engines do not like heat. I would check it out as soon as you can....
Old Aug 18, 2015 | 01:49 AM
Kiwijeff's Avatar
Thanks, I've only had it two weeks, and today I took it for a ride outer town. First time I got to see how it was on open road, instead of around town. The gauge never got over halfway, so I'm not to concerned, but I will go through it before the trip.
Old Aug 18, 2015 | 02:30 AM
I think it was June82000 that mentioned in another post that the Land Rover D1 and D2 dashboard temperature gage has three displays; cold, middle (normal temp), and "its too late." I agree 100%. DO NOT trust the factory dashboard temperature gage, it will not tell you until it is too late that you have overheated. Get an aftermarket gage - Please!
Old Aug 18, 2015 | 05:39 AM
june82000's Avatar
Ha ha, thanks for noticing!
OP - if the needle is hanging around somewhere in the middle then I'd say you're OK. But if it starts creeping up much past that then you should start getting concerned. For added peace of mind like I mentioned, you could install an inexpensive gauge so you can see a temperature value inside the vehicle. 180 degree thermostats are apparently wrote these engines like the most. Because these engines are made entirely of aluminum they do not respond well to overheating.
