Sponsored by: CARiD
95 D1 vibrating
Old Nov 18, 2014 | 02:48 PM
Discotim369's Avatar
Default 95 D1 vibrating
What would cause my disco to vigorously vibrate while driving? It only does it between 25 and 35 mph.
Old Nov 18, 2014 | 07:30 PM
MM3846's Avatar
tire balance
Old Nov 18, 2014 | 10:01 PM
I had my tires balanced not to long ago. I'm think it might be bad u joints in my drive lines but not sure?
Old Nov 19, 2014 | 06:50 AM
drowssap's Avatar
bad u joints
Old Nov 19, 2014 | 07:16 AM
fishEH's Avatar
Can you elaborate on the vibrating any? Does it change with speed? Does your steering wheel shake?
Old Nov 19, 2014 | 10:13 AM
MM3846's Avatar
i've found that 90% of the time if the vibe only happens in between certain speeds it is tire balance. but yea, elaborate on the vibe. wheel shake? whole truck shake? low frequency hum?
Old Nov 19, 2014 | 07:43 PM
The whole vehicle shakes extreamly bad but only between 25 and 35 MPH, and smooths out after that. It kinda seems like my drive lines are wobbleing but they are both tight thats why I think it might be bad u joints.
Old Nov 20, 2014 | 09:58 AM
MM3846's Avatar
so your driveshaft joints are tight. you don't have axle shaft u joints, but you could have bad/loose wheel bearings. swap the tires front to back and see if it helps. is the truck lifted? you have a 95 so you still have the rear rotoflex thing... hows that look? with a lift that will wear or show wear faster than normal.
Old Nov 21, 2014 | 12:12 PM
My vehicle is lifted 2 inches, I've checked my wheel bearings and they seem just fine. I don't know what rotoflex thing your talking about? I can try swapping my tires.
Old Nov 21, 2014 | 12:52 PM
MM3846's Avatar
its the thing you have on your rear driveshaft instead of a ujoint at the axle yoke.
